Le Deal du moment : -50%
-50% Baskets Nike Dunk Low
64.99 €
 Question au specialistes Carter
2 participants
Question au specialistes Carter Empty
MessageSujet: Question au specialistes Carter   Question au specialistes Carter EmptyMer 23 Oct 2013, 10:55
Quelle la différence entre ces deux modèles ?
Question au specialistes Carter Simple10
Question au specialistes Carter Toosim10
MessageSujet: Re: Question au specialistes Carter   Question au specialistes Carter EmptyMer 23 Oct 2013, 12:18
Tu sais pas lire ???
Sinon je crois que c'est le système de ressort
MessageSujet: Re: Question au specialistes Carter   Question au specialistes Carter EmptyMer 23 Oct 2013, 12:24
Twisted Evil  je sais lire mais pas l'anglais Wink  apres le simple je sait que c'est le fameux ITS mais le too simple ???
MessageSujet: Re: Question au specialistes Carter   Question au specialistes Carter EmptyMer 23 Oct 2013, 12:27
il parle pas de ITS sur le nouveau
Carter Enterprises introduces a "sure to dominate" model for 2012, the Easy 1.
The Easy 1 has combined the top features of two of their best selling releases in to one model.
New from Carter is an amazing new release that is just Too Simple. Based on the hugely successful “Simple 1” release, the new Too Simple now features Carter Enterprises unique “double sear” trigger system which makes for the finest trigger travel adjustment on the market. A new set-screw tension adjustment allows for a super micro adjustable trigger tension by simply turning a screw. In addition, a newly improved, self-closing jaw allows for a cleaner release and trouble free loading onto a D-loop with just one push of a button. Like the Simple 1 the new Too Simple has an extremely comfortable handle, auto locking jaw with an ultra short head to help increase speed. The new Too Simple is available in a two, three and four finger handle configuration.
» [CO] Question sur Carter Solution
» Taille décocheur Carter Only - Carter Chocolate lite
» Forme Carter Attraction - Carter Insatiable
» BT Carter 2 Moons ou Carter Only ou autre?
» carter
